TWO 16b tombstones/ FINISHED!
(06-01-2015, 02:47 PM)PhilcoMike Wrote: Kind of interested in the difference in power transformers between the two chassis.
The 5-band 16 chassis uses a vertical mounting power transformer.
The 4-band 16, which came later, uses a horizontal mounting power transformer.
Both are correct for their respective chassis.
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 06-01-2015, 08:01 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
