Phonograph motor fried??
odpilot
you checked and answered you own question
On the formerly restored 53-1750, I get 118 Volts coming into the phonograph motor.  On the new one I am restoring, voltmeter reads 1.5Volts coming into the switch
so check before switch. you have one to check against
Phonograph motor fried?? - by ODPILOT - 05-28-2015, 02:02 PM
RE: Phonograph motor fried?? - by Warren - 05-28-2015, 03:13 PM
RE: Phonograph motor fried?? - by ODPILOT - 05-30-2015, 09:10 AM
RE: Phonograph motor fried?? - by jerryhawthorne - 05-30-2015, 02:37 PM
RE: Phonograph motor fried?? - by ODPILOT - 06-01-2015, 11:49 AM
RE: Phonograph motor fried?? - by morzh - 06-01-2015, 11:58 AM
RE: Phonograph motor fried?? - by sam - 06-02-2015, 04:14 AM
RE: Phonograph motor fried?? - by ODPILOT - 06-02-2015, 12:19 PM
RE: Phonograph motor fried?? - by morzh - 06-02-2015, 01:13 PM
RE: Phonograph motor fried?? - by sam - 06-02-2015, 08:01 PM
RE: Phonograph motor fried?? - by morzh - 06-02-2015, 09:31 PM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 04:35 AM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 09:20 AM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 12:26 PM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 03:12 PM
RE: Phonograph motor fried?? - by jerryhawthorne - 06-03-2015, 03:45 PM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 03:58 PM
RE: Phonograph motor fried?? - by jerryhawthorne - 06-03-2015, 04:36 PM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 07:17 PM
RE: Phonograph motor fried?? - by ODPILOT - 06-03-2015, 09:06 PM
RE: Phonograph motor fried?? - by sam - 06-04-2015, 03:46 AM
There are currently 5822 online users. [Complete List]
» 1 Member(s) | 5821 Guest(s)
