Philco 81 Front End Problem
Dr.Volts Wrote:Hooray! I got it fixed. Exray pretty much pinpointed the problem. There was a cold solder joint =.
Lucky guess Icon_smile
-Bill
Philco 81 Front End Problem - by Guest - 02-02-2009, 07:56 PM
Re: Philco 81 Front End Problem - by exray - 02-02-2009, 08:41 PM
Re: Philco 81 Front End Problem - by Guest - 02-02-2009, 10:00 PM
Re: Philco 81 Front End Problem - by exray - 02-02-2009, 10:45 PM
Re: Philco 81 Front End Problem - by Steve Davis - 02-02-2009, 11:12 PM
Re: Philco 81 Front End Problem - by Guest - 02-05-2009, 08:48 PM
Re: Philco 81 Front End Problem - by Guest - 02-06-2009, 06:45 PM
Re: Philco 81 Front End Problem - by exray - 02-06-2009, 07:01 PM
There are currently 10381 online users. [Complete List]
» 3 Member(s) | 10378 Guest(s)
