Phonograph motor fried??
Well, we have an expression "to be lost amongst three pine woods".
Like you said, one switch (two sections), board switch, power cord and the motor itself. And whatever connects them.
2-minute buzz job with a meter.
You have to go through EVERY conductive piece. Wire on the board - buzz the wire.
It is as simple as this: if the voltage does not get to the motor it drops on something else.
Phonograph motor fried?? - by ODPILOT - 05-28-2015, 02:02 PM
RE: Phonograph motor fried?? - by Warren - 05-28-2015, 03:13 PM
RE: Phonograph motor fried?? - by ODPILOT - 05-30-2015, 09:10 AM
RE: Phonograph motor fried?? - by jerryhawthorne - 05-30-2015, 02:37 PM
RE: Phonograph motor fried?? - by ODPILOT - 06-01-2015, 11:49 AM
RE: Phonograph motor fried?? - by morzh - 06-01-2015, 11:58 AM
RE: Phonograph motor fried?? - by sam - 06-02-2015, 04:14 AM
RE: Phonograph motor fried?? - by ODPILOT - 06-02-2015, 12:19 PM
RE: Phonograph motor fried?? - by morzh - 06-02-2015, 01:13 PM
RE: Phonograph motor fried?? - by sam - 06-02-2015, 08:01 PM
RE: Phonograph motor fried?? - by morzh - 06-02-2015, 09:31 PM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 04:35 AM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 09:20 AM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 12:26 PM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 03:12 PM
RE: Phonograph motor fried?? - by jerryhawthorne - 06-03-2015, 03:45 PM
RE: Phonograph motor fried?? - by morzh - 06-03-2015, 03:58 PM
RE: Phonograph motor fried?? - by jerryhawthorne - 06-03-2015, 04:36 PM
RE: Phonograph motor fried?? - by sam - 06-03-2015, 07:17 PM
RE: Phonograph motor fried?? - by ODPILOT - 06-03-2015, 09:06 PM
RE: Phonograph motor fried?? - by sam - 06-04-2015, 03:46 AM
There are currently 6069 online users. [Complete List]
» 2 Member(s) | 6067 Guest(s)
