It's a 220!
Definitely agree with you about the model 20's spreaker! Compare a model 70/90 speaker with the 20, assuming the appropriate output transformer is used, and you will see what I mean!
It's a 220! - by Jayce - 05-15-2015, 07:22 PM
RE: It's a 220! - by mikethedruid - 05-19-2015, 01:27 AM
RE: It's a 220! - by morzh - 05-19-2015, 09:57 AM
RE: It's a 220! - by fegravel - 05-19-2015, 02:37 PM
RE: It's a 220! - by AI2V - 05-31-2015, 10:48 AM
RE: It's a 220! - by PhilcoJohn - 06-02-2015, 06:58 AM
RE: It's a 220! - by morzh - 06-02-2015, 09:53 AM
RE: It's a 220! - by TA Forbes - 06-03-2015, 09:12 AM
RE: It's a 220! - by morzh - 06-03-2015, 09:25 AM
RE: It's a 220! - by TA Forbes - 06-03-2015, 09:55 AM
RE: It's a 220! - by morzh - 06-03-2015, 10:23 AM
