Hallicrafters S-120
I just happen to have a 50 ohm 10 watt resistor. I'll install it tomorrow.
I just finished replacing old/bad parts and fired this thing up today, but it's not working. Then one of the dial lights blew. They seemed overly bright.
Then again, I have 128 volts at the outlets in my house.
Hallicrafters S-120 - by Eric T - 05-04-2015, 11:49 AM
RE: Hallicrafters S-120 - by David - 05-14-2015, 05:37 PM
RE: Hallicrafters S-120 - by Eric T - 05-16-2015, 08:03 AM
RE: Hallicrafters S-120 - by David - 05-16-2015, 02:50 PM
RE: Hallicrafters S-120 - by Eric T - 06-03-2015, 03:16 PM
RE: Hallicrafters S-120 - by David - 06-03-2015, 07:05 PM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 12:55 AM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 06:33 PM
RE: Hallicrafters S-120 - by David - 06-04-2015, 07:13 PM
RE: Hallicrafters S-120 - by Eric T - 06-05-2015, 10:16 AM
RE: Hallicrafters S-120 - by David - 06-05-2015, 12:59 PM
RE: Hallicrafters S-120 - by Eric T - 06-07-2015, 06:08 PM
RE: Hallicrafters S-120 - by David - 06-07-2015, 07:34 PM
RE: Hallicrafters S-120 - by Eric T - 06-08-2015, 02:43 PM
RE: Hallicrafters S-120 - by David - 01-15-2021, 02:49 PM
Eico 232 VTVM Schematic
There are currently 6503 online users. [Complete List]
» 2 Member(s) | 6501 Guest(s)
