Dial Replacement
When replacing a Philco dial (this one's a model 80) what is the preferred way to attach the reproduction?
They are held on as you know by very small rivets. Drilling out the rivets is no problem but what do you use in their place? Will contact cement hold?
Thanks.
Dial Replacement - by jmac3ky - 06-04-2015, 01:47 PM
RE: Dial Replacement - by TA Forbes - 06-04-2015, 02:22 PM
RE: Dial Replacement - by jmac3ky - 06-04-2015, 02:38 PM
RE: Dial Replacement - by morzh - 06-04-2015, 02:30 PM
There are currently 4978 online users. [Complete List]
» 1 Member(s) | 4977 Guest(s)
