Can anyone identify this radio?
On the radio maybe 40-50 depends on the condition of the innards. The Maggie horn may be worth some money depending on what model it is. Do a little internet research to find the answer.
Can anyone identify this radio? - by murf - 06-03-2015, 04:15 PM
RE: Can anyone identify this radio? - by murf - 06-04-2015, 04:42 PM
RE: Can anyone identify this radio? - by Radioroslyn - 06-04-2015, 05:35 PM
RE: Can anyone identify this radio? - by Arran - 06-05-2015, 03:04 AM
RE: Can anyone identify this radio? - by murf - 07-26-2015, 08:41 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3612 online users. [Complete List]
» 1 Member(s) | 3611 Guest(s)
