Can anyone identify this radio?
A home brew set would be my guess as well, both because of having no markings and because it only has two dials. Building a two dial set is simpler then a three dialer and requires fewer parts as there is at least one less tuned circuit. Some inside shots would be helpful, but I do like that marbling in the front panel.
Make sure that you bring a 9 volt battery along to test the driver on the horn, if it's good you should hear a click, if not then either the leads have a problem or the coil in the driver is shot.
Can anyone identify this radio? - by murf - 06-03-2015, 04:15 PM
RE: Can anyone identify this radio? - by murf - 06-04-2015, 04:42 PM
RE: Can anyone identify this radio? - by Arran - 06-05-2015, 03:04 AM
RE: Can anyone identify this radio? - by murf - 07-26-2015, 08:41 PM
There are currently 10503 online users. [Complete List]
» 2 Member(s) | 10501 Guest(s)
