  • 1 Vote(s) - 3 Average
Philco 604C Electronic Restoration
I forgot to mention: In case you are wondering the differences between the 604C and the later 37-604C, they are as follows:
* The 604 uses standard base tubes. The 37-604 uses octals.
* The 604 only has a three-screw terminal strip providing connections to a longwire antenna as well as two screws for Philco's High Efficiency Aerial. The 37-604 has five screw terminals - two (RED and BLK) forPhilco's High Efficiency Aerial, one for ground (!), and two more used as "shorting" terminals. See the 37-604 schematic for more info.
Well, a few days ago, I pulled the chassis out of the cabinet and dived in.
[Image: http://www.philcoradio.com/images/phorum..._00006.jpg]
Removing the screws holding the bottom chassis cover in place...
[Image: http://www.philcoradio.com/images/phorum..._00007.jpg]
A look underneath. As you can see, someone else was in here before me. I will try to make this look neater than it does now.
[Image: http://www.philcoradio.com/images/phorum..._00008.jpg]
A closer look at the antenna screw terminals. As you can see, the terminal board is broken.
Now let's take a close look at the dial scale...
[Image: http://www.philcoradio.com/images/phorum..._00009.jpg]
[Image: http://www.philcoradio.com/images/phorum..._00010.jpg]
Broken in two places, and part of the numbering is worn off. Fortunately, Radio Daze sells a 37-604 replica dial scale. I guess I will have to purchase one. Icon_sad
RE: Philco 604C Electronic Restoration - by Ron Ramirez - 06-05-2015, 07:07 PM
RE: Philco 604C Electronic Restoration - by sam - 06-14-2015, 10:43 PM
RE: Philco 604C Electronic Restoration - by Arran - 06-17-2015, 12:54 AM
RE: Philco 604C Electronic Restoration - by Arran - 06-19-2015, 12:07 AM
RE: Philco 604C Electronic Restoration - by sam - 07-16-2015, 04:17 AM
RE: Philco 604C Electronic Restoration - by sam - 07-19-2015, 08:14 PM
RE: Philco 604C Electronic Restoration - by morzh - 10-25-2020, 08:12 PM
Users browsing this thread: 14 Guest(s)
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4548 online users. [Complete List]
» 2 Member(s) | 4546 Guest(s)
