Hallicrafters S-120
My S-38Ee takes about 10-15 minutes to warm up then good to go. Like I said fun sets to play with If you happen to be up between 3AM-5AM tune between 9.0-11.0 for radio OZ  David
Hallicrafters S-120 - by Eric T - 05-04-2015, 11:49 AM
RE: Hallicrafters S-120 - by David - 05-14-2015, 05:37 PM
RE: Hallicrafters S-120 - by Eric T - 05-16-2015, 08:03 AM
RE: Hallicrafters S-120 - by David - 05-16-2015, 02:50 PM
RE: Hallicrafters S-120 - by Eric T - 06-03-2015, 03:16 PM
RE: Hallicrafters S-120 - by David - 06-03-2015, 07:05 PM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 12:55 AM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 06:33 PM
RE: Hallicrafters S-120 - by David - 06-04-2015, 07:13 PM
RE: Hallicrafters S-120 - by Eric T - 06-05-2015, 10:16 AM
RE: Hallicrafters S-120 - by David - 06-05-2015, 12:59 PM
RE: Hallicrafters S-120 - by Eric T - 06-07-2015, 06:08 PM
RE: Hallicrafters S-120 - by David - 06-07-2015, 07:34 PM
RE: Hallicrafters S-120 - by Eric T - 06-08-2015, 02:43 PM
RE: Hallicrafters S-120 - by David - 01-15-2021, 02:49 PM
Eico 232 VTVM Schematic
There are currently 7181 online users. [Complete List]
» 2 Member(s) | 7179 Guest(s)
