TWO 16b tombstones/ FINISHED!
#31
I have repainted the shields for the 3rd time now and even look better than last time. I could not find the nickel paint from krylon on the second time and I used bright silver which looks very good but I bought some rustoleum  that the sheids really looks like they been plated. Check it out, what do you think Ron? Icon_think Icon_think Icon_think  It says metallic but there are no metallic flakes in the paint which is better, go figure Icon_question Its a solid color like plating would be, no metallic Icon_thumbup
TWO 16b tombstones/ FINISHED! - by Fred Taylor - 05-24-2015, 05:15 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 05-24-2015, 07:07 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 05-24-2015, 07:02 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-24-2015, 08:01 PM
RE: Two at a time . Philco 16b,s - by Art Hoch - 05-26-2015, 08:15 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-26-2015, 09:34 PM
RE: Two at a time . Philco 16b,s - by radiohenry - 05-28-2015, 06:18 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-30-2015, 09:54 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-30-2015, 10:13 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-30-2015, 10:18 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 05-31-2015, 07:36 AM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-31-2015, 10:18 AM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 05-31-2015, 12:40 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 05-31-2015, 02:29 PM
RE: Two at a time . Philco 16b,s - by PhilcoMike - 06-01-2015, 02:47 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-01-2015, 06:08 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 06-01-2015, 08:01 PM
RE: Two at a time . Philco 16b,s - by morzh - 06-01-2015, 03:02 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 06-01-2015, 07:59 PM
RE: Two at a time . Philco 16b,s - by morzh - 06-01-2015, 08:57 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-02-2015, 06:29 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 06-02-2015, 06:44 PM
RE: Two at a time . Philco 16b,s - by Mondial - 06-02-2015, 11:08 PM
RE: Two at a time . Philco 16b,s - by SteveG - 06-02-2015, 11:33 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-06-2015, 08:28 AM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-07-2015, 08:57 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-07-2015, 09:39 PM
RE: Two at a time . Philco 16b,s - by Ron Ramirez - 06-07-2015, 10:15 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-08-2015, 07:25 PM
RE: Two at a time . Philco 16b,s - by Warren - 06-08-2015, 11:26 PM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-09-2015, 08:23 AM
RE: Two at a time . Philco 16b,s - by Fred Taylor - 06-11-2015, 07:36 PM
RE: TWO 16b tombstones/ FINISHED! - by morzh - 06-12-2015, 09:31 AM
RE: TWO 16b tombstones/ FINISHED! - by sam - 06-12-2015, 11:42 AM
RE: TWO 16b tombstones/ FINISHED! - by morzh - 06-12-2015, 12:25 PM
RE: TWO 16b tombstones/ FINISHED! - by Art Hoch - 06-13-2015, 06:12 PM
RE: TWO 16b tombstones/ FINISHED! - by Warren - 06-15-2015, 12:51 AM
RE: TWO 16b tombstones/ FINISHED! - by PTurney - 10-19-2015, 03:29 PM
RE: 16b tombstone ?,s - by klondike98 - 05-24-2015, 06:07 PM
There are currently 10107 online users. [Complete List]
» 2 Member(s) | 10105 Guest(s)
