635 Radiobar Value
Hi - There is a 635 Radiobar for sale locally and I have no idea as to the value. I have seen pictures. It looks pretty nice and and appears to have the glassware. Any ideas as to its' value before I go look at it?
Jay
635 Radiobar Value - by Jayg30 - 02-08-2009, 04:15 PM
Re: 635 Radiobar Value - by 49Stude63 - 02-08-2009, 04:36 PM
There are currently 7048 online users. [Complete List]
» 2 Member(s) | 7046 Guest(s)
