38-C-12A coronation model value?
(06-09-2015, 06:18 AM)Radioroslyn Wrote:  Don't know about worth but the dial is normal. It did have a dark brown paint on the wood but when it was stripped it was removed. Add some brown the the edge and it will look original.
ps How's the cafe??
pss You may want to try to pull the dial pointer out a bit if possible they have a nasty habit of tearing the foil off of the dial. Grille cloth looks original.
Thanks Terry. I do plan on re-lacquering when I get a chance. I don't know about value either, but I only know of one other with the coronation logo. It may be rare, but not necessarily worth much. I appreciate your response.
38-C-12A coronation model value? - by Smokey - 06-08-2015, 08:39 AM
RE: 38-C-12A coronation model value? - by Smokey - 06-09-2015, 08:04 AM
