49-1600 console serial 95414
 Value? Anywhere between free and maybe $50 on a very good day, that's if everything works, radio and phonograph. From my personal point of view I would not waste my time with it unless it's really cheap or free, for one thing it's too new, for another it has rather uninspired styling, finally it takes up floor space that could be occupied by something much more interesting, like any Philco console made between 1928 and 1948. If it had a television set built into one end I would say different, the radios built into those usually had an FM band at least.
49-1600 console serial 95414 - by brownie45 - 06-11-2015, 08:34 AM
RE: 49-1600 console serial 95414 - by sam - 06-11-2015, 11:43 AM
RE: 49-1600 console serial 95414 - by brownie45 - 06-11-2015, 12:59 PM
RE: 49-1600 console serial 95414 - by Radioroslyn - 06-11-2015, 09:35 PM
RE: 49-1600 console serial 95414 - by morzh - 06-11-2015, 10:12 PM
RE: 49-1600 console serial 95414 - by Arran - 06-11-2015, 11:36 PM
RE: 49-1600 console serial 95414 - by brownie45 - 06-12-2015, 08:10 AM
There are currently 7187 online users. [Complete List]
» 1 Member(s) | 7186 Guest(s)
