Model 70 Help for the newbie
As always thank you Ron. It's pretty exciting to see it come back together again. I've ordered some grommets, and in the meantime, I think I'll get started on the cabinet. I was looking at a picture of a model 70/71 that you had posted a while ago. Did the 70 originally have brown trim along the base and on the edges of the face, or is that just a Darker Walnut lacquer?
Model 70 Help for the newbie - by mikehorning - 02-06-2009, 10:57 PM
Re: Model 70 Help for the newbie - by Ron Ramirez - 02-06-2009, 11:01 PM
Re: Model 70 Help for the newbie - by mikehorning - 02-07-2009, 12:02 AM
Re: Model 70 Help for the newbie - by mikehorning - 02-07-2009, 11:56 PM
Re: Model 70 Help for the newbie - by Ron Ramirez - 02-08-2009, 12:36 AM
Re: Model 70 Help for the newbie - by radiorich - 02-09-2009, 01:22 AM
Re: Model 70 Help for the newbie - by Ron Ramirez - 02-09-2009, 07:51 AM
Re: Model 70 Help for the newbie - by mikehorning - 02-09-2009, 10:33 PM
