Capacitor Part Numbers
I am in the process of restoring a Philco radio/phono model #46-1201, code 121. Aside from having a heck of a time trying to find a code 121 schematic, I've also had trouble finding what the value of some of the capacitors are, using Philco's part number. On some of the capacitors, the values are written, on others the values are either missing or have faded and are not legible. I have been looking on this site and others for a listing of the codes, but have only found them up to the mid-30s. Does anybody know where I can find a listing for Philco's capacitor part numbers, which would tell me their values?
Thank you,
Microtouch
Capacitor Part Numbers - by Guest - 02-10-2009, 07:51 PM
Re: Capacitor Part Numbers - by Texasrocker - 02-10-2009, 11:21 PM
Re: Capacitor Part Numbers - by Guest - 02-11-2009, 07:09 AM
Re: Capacitor Part Numbers - by Texasrocker - 02-12-2009, 01:48 AM
Re: Capacitor Part Numbers - by Guest - 02-12-2009, 06:57 AM
Re: Capacitor Part Numbers - by Guest - 02-13-2009, 02:17 PM
Re: Capacitor Part Numbers - by Texasrocker - 02-14-2009, 04:17 AM
There are currently 10182 online users. [Complete List]
» 3 Member(s) | 10179 Guest(s)
