Threads: 562
Sam,
you should start cutting little parts of this radio and send him one by one.
In sacks with some fish in it.
But then do not send all of them or he will reassemble it. And will eat the fish.
RE: Mikes 16B, Not Sams - by morzh - 06-15-2015, 10:43 AM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 6237 online users. [Complete List] » 1 Member(s) | 6236 Guest(s)
