Philco 70A
I asked for the s/n and he sent me this: 446650  he wasn't sure if it was the s/n but said that it was stamped into the chassis.  Do you think that it is above 22,000 mark?
Here's a pic he sent me of the underside.  Can anybody tell me if it's the model above s/n 22,000?
Thanks.
Crist
Philco 70A - by Crist Rigotti - 06-17-2015, 11:24 PM
RE: Philco 70A - by Phlogiston - 06-18-2015, 12:25 AM
RE: Philco 70A - by morzh - 06-18-2015, 09:41 AM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 09:47 AM
RE: Philco 70A - by Phlogiston - 06-18-2015, 10:38 AM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 10:41 AM
RE: Philco 70A - by Steve Davis - 06-18-2015, 12:25 PM
RE: Philco 70A - by Steve Davis - 06-18-2015, 12:31 PM
RE: Philco 70A - by GarySP - 06-18-2015, 12:52 PM
RE: Philco 70A - by TA Forbes - 06-18-2015, 01:03 PM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 02:34 PM
RE: Philco 70A - by Ron Ramirez - 06-18-2015, 05:53 PM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 08:25 PM
RE: Philco 70A - by Ron Ramirez - 06-18-2015, 08:51 PM
RE: Philco 70A - by morzh - 06-18-2015, 08:57 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 02:03 PM
RE: Philco 70A - by plymouthrod - 06-19-2015, 02:25 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 04:16 PM
RE: Philco 70A - by Ron Ramirez - 06-19-2015, 05:38 PM
RE: Philco 70A - by KCMike - 06-19-2015, 07:53 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 09:47 PM
RE: Philco 70A - by Ron Ramirez - 06-19-2015, 10:26 PM
RE: Philco 70A - by Arran - 06-19-2015, 10:36 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 10:41 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 11:21 PM
RE: Philco 70A - by KCMike - 06-20-2015, 01:51 PM
RE: Philco 70A - by Crist Rigotti - 06-20-2015, 07:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3799 online users. [Complete List]
» 1 Member(s) | 3798 Guest(s)
