Scored a 41-280x this morning!
22 is just fine for general hookup, it's just when buying cloth covered from Daze I only see 18 and 20.
http://www.radiodaze.com/cloth-covered/
Scored a 41-280x this morning! - by GarySP - 06-13-2015, 05:11 PM
RE: Scored a 41-280x this morning! - by morzh - 06-13-2015, 06:56 PM
RE: Scored a 41-280x this morning! - by TA Forbes - 06-14-2015, 09:48 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-14-2015, 10:16 PM
RE: Scored a 41-280x this morning! - by Arran - 06-15-2015, 01:02 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-16-2015, 08:58 AM
RE: Scored a 41-280x this morning! - by Art Hoch - 06-19-2015, 09:49 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-17-2015, 11:40 AM
RE: Scored a 41-280x this morning! - by morzh - 06-17-2015, 12:15 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-18-2015, 01:11 PM
RE: Scored a 41-280x this morning! - by morzh - 06-18-2015, 06:24 PM
RE: Scored a 41-280x this morning! - by morzh - 06-18-2015, 08:53 PM
RE: Scored a 41-280x this morning! - by morzh - 06-19-2015, 10:42 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-18-2015, 09:25 PM
RE: Scored a 41-280x this morning! - by Arran - 06-19-2015, 04:27 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-20-2015, 04:17 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-20-2015, 07:26 PM
RE: Scored a 41-280x this morning! - by Art Hoch - 06-20-2015, 09:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
