Scored a 41-280x this morning!
Yep. I just kinda prefer cloth covered.
That said, I would prefer it even more if it came with that beige grayish hue Philco used, not those bright parrot ones they sell, but it is what it is....I am tempted to try that relic factory in MA who still make original cloth covered wire, just don't remember if they sell retail quantities.
PS. Just thought...for 40s radios cloth covered is not needed as they used colored rubber one. So, yep, you are absolutely right, for these AWG22 with pastic jacketing is just fine.
Scored a 41-280x this morning! - by GarySP - 06-13-2015, 05:11 PM
RE: Scored a 41-280x this morning! - by morzh - 06-13-2015, 06:56 PM
RE: Scored a 41-280x this morning! - by TA Forbes - 06-14-2015, 09:48 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-14-2015, 10:16 PM
RE: Scored a 41-280x this morning! - by Arran - 06-15-2015, 01:02 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-16-2015, 08:58 AM
RE: Scored a 41-280x this morning! - by Art Hoch - 06-19-2015, 09:49 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-17-2015, 11:40 AM
RE: Scored a 41-280x this morning! - by morzh - 06-17-2015, 12:15 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-18-2015, 01:11 PM
RE: Scored a 41-280x this morning! - by morzh - 06-18-2015, 06:24 PM
RE: Scored a 41-280x this morning! - by morzh - 06-18-2015, 08:53 PM
RE: Scored a 41-280x this morning! - by morzh - 06-19-2015, 10:42 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-18-2015, 09:25 PM
RE: Scored a 41-280x this morning! - by Arran - 06-19-2015, 04:27 AM
RE: Scored a 41-280x this morning! - by GarySP - 06-20-2015, 04:17 PM
RE: Scored a 41-280x this morning! - by GarySP - 06-20-2015, 07:26 PM
RE: Scored a 41-280x this morning! - by Art Hoch - 06-20-2015, 09:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3243 online users. [Complete List]
» 1 Member(s) | 3242 Guest(s)
