38-10 tuner subassembly and Temp Speaker Question
Also,
The unit is missing the speaker and output transformer. Until I find a suitable replacement I was thinking about using something off the shelf. Can anyone recommend a replacement speaker and where to get one? I figure a cheap output transformer from Antique Electric Supply will wire right up after looking at the schematic. Any suggestions.
Daniel
Re: 38-10 tuner assembly - by 2MERCS - 02-11-2009, 07:46 PM
Re: 38-10 tuner subassembly mounting - by 2MERCS - 02-14-2009, 06:35 PM
There are currently 10103 online users. [Complete List]
» 2 Member(s) | 10101 Guest(s)
