41-623 BOL
hey greg
so your getting almost 5 volts to light  but it works with 6volt battery
you need to see why your not getting 6volts #66 adjustable resister good ?
sounds like your not getting correct voltage
and they are special bulbs I think
they are hard as H**l some times to get out little heat maybe
sam
41-623 BOL - by NostalgiaRadioTime - 06-17-2015, 10:13 PM
RE: 41-623 BOL - by sam - 06-18-2015, 01:07 PM
RE: 41-623 BOL - by NostalgiaRadioTime - 06-18-2015, 07:50 PM
RE: 41-623 BOL - by NostalgiaRadioTime - 06-18-2015, 09:39 PM
RE: 41-623 BOL - by sam - 06-19-2015, 04:12 AM
RE: 41-623 BOL - by sam - 06-23-2015, 01:30 PM
RE: 41-623 BOL - by marv - 06-24-2015, 08:57 PM
RE: 41-623 BOL - by NostalgiaRadioTime - 06-24-2015, 11:01 PM
RE: 41-623 BOL - by sam - 06-25-2015, 04:37 AM
RE: 41-623 BOL - by NostalgiaRadioTime - 06-29-2015, 08:33 PM
RE: 41-623 BOL - by sam - 06-30-2015, 04:12 AM
RE: 41-623 BOL - by NostalgiaRadioTime - 06-30-2015, 10:39 PM
RE: 41-623 BOL - by sam - 06-30-2015, 11:48 PM
RE: 41-623 BOL - by sam - 08-30-2015, 10:29 PM
RE: 41-623 BOL - by NostalgiaRadioTime - 08-30-2015, 10:50 PM
RE: 41-623 BOL - by Crist Rigotti - 08-30-2015, 11:07 PM
RE: 41-623 BOL - by sam - 08-30-2015, 11:22 PM
There are currently 5786 online users. [Complete List]
» 3 Member(s) | 5783 Guest(s)
