Use of RCA 237 Tubes in Radio with AC Powered Filiments
  If all of these tubes have an indirectly heated cathode then they should work on either AC or DC. Why would anyone bother using a an indirectly heated cathode in a DC only tube when they could use a directly heated one which is simpler to construct?
There are currently 5944 online users. [Complete List]
» 1 Member(s) | 5943 Guest(s)
