need help Model 19 code 126
(06-20-2015, 03:14 PM)earlyradios Wrote:  Hi all. I have a model 19 code 126. Need to find a clear schematic for it.  I can pull up the basic 19 and the code 128 from N/A but not this one.  It seems to be different than these two however most like the original 19. Problem is with that one I can't make out the part numbers on it. Anyone have a clear one?  Icon_crazy
Order one from Chuck Schwark. Inexpensive and you will have a good quality document.
need help Model 19 code 126 - by earlyradios - 06-20-2015, 03:14 PM
RE: need help Model 19 code 126 - by morzh - 06-20-2015, 03:27 PM
RE: need help Model 19 code 126 - by Ron Ramirez - 06-20-2015, 03:44 PM
RE: need help Model 19 code 126 - by Radioroslyn - 06-20-2015, 03:44 PM
RE: need help Model 19 code 126 - by earlyradios - 06-20-2015, 03:59 PM
RE: need help Model 19 code 126 - by Phlogiston - 06-20-2015, 08:39 PM
There are currently 4306 online users. [Complete List]
» 3 Member(s) | 4303 Guest(s)
