Philco 70A
(06-20-2015, 01:51 PM)Mike Wrote:  I think you have a good one to restore. Pretty clean and looks like only light surface rust on top of chassis, nice and roomy underneath and only 6 bakelite blocks to restuff.
Yeah, i think so too!  Thanks.
Crist
Philco 70A - by Crist Rigotti - 06-17-2015, 11:24 PM
RE: Philco 70A - by Phlogiston - 06-18-2015, 12:25 AM
RE: Philco 70A - by morzh - 06-18-2015, 09:41 AM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 09:47 AM
RE: Philco 70A - by Phlogiston - 06-18-2015, 10:38 AM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 10:41 AM
RE: Philco 70A - by Steve Davis - 06-18-2015, 12:25 PM
RE: Philco 70A - by Steve Davis - 06-18-2015, 12:31 PM
RE: Philco 70A - by GarySP - 06-18-2015, 12:52 PM
RE: Philco 70A - by TA Forbes - 06-18-2015, 01:03 PM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 02:34 PM
RE: Philco 70A - by Ron Ramirez - 06-18-2015, 05:53 PM
RE: Philco 70A - by Crist Rigotti - 06-18-2015, 08:25 PM
RE: Philco 70A - by Ron Ramirez - 06-18-2015, 08:51 PM
RE: Philco 70A - by morzh - 06-18-2015, 08:57 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 02:03 PM
RE: Philco 70A - by plymouthrod - 06-19-2015, 02:25 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 04:16 PM
RE: Philco 70A - by Ron Ramirez - 06-19-2015, 05:38 PM
RE: Philco 70A - by KCMike - 06-19-2015, 07:53 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 09:47 PM
RE: Philco 70A - by Ron Ramirez - 06-19-2015, 10:26 PM
RE: Philco 70A - by Arran - 06-19-2015, 10:36 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 10:41 PM
RE: Philco 70A - by Crist Rigotti - 06-19-2015, 11:21 PM
RE: Philco 70A - by KCMike - 06-20-2015, 01:51 PM
RE: Philco 70A - by Crist Rigotti - 06-20-2015, 07:51 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3459 online users. [Complete List]
» 1 Member(s) | 3458 Guest(s)
