Philco 38-116 shipping questions.
 Check and see what the hard limit is for weight by bus, it's 100 pounds or under if I remember correctly. This means that the chassis will most definitely have to be shipped separately, possibly the speaker and acoustical resonators as well, a 38-116 is not a light cabinet.
Philco 38-116 shipping questions. - by louxwe - 06-24-2015, 11:14 AM
RE: Philco 38-116 shipping questions. - by morzh - 06-24-2015, 11:28 AM
RE: Philco 38-116 shipping questions. - by Arran - 06-25-2015, 11:50 PM
RE: Philco 38-116 shipping questions. - by morzh - 06-26-2015, 02:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6691 online users. [Complete List]
» 1 Member(s) | 6690 Guest(s)
