Philco 39-55
I have a 39-55 remote set that I have had for about 20 years. When I first purchased it I got is working and the radio and remote control were very good performers. At that time however it was not yet common to do a full recap and it needs it now. The main problem that I have with it now is that I can not turn it on. When I hit the switch the volume motor does not turn. Is there a starting capacitor for this motor? I see a 30mfd x 30 volt cap in the circuit and it looks to be a 30 volt AC cap but the schematic that I have does not specify this. Any suggestions?
BTW, Ron, I will still get you better pictures of that 1942 remote control. I just have not had the time for the last few weeks.
Philco 39-55 - by Guest - 12-28-2005, 06:42 PM
[No subject] - by Chuck Schwark - 12-28-2005, 07:19 PM
[No subject] - by Guest - 12-28-2005, 07:27 PM
[No subject] - by Chuck Schwark - 12-28-2005, 07:43 PM
[No subject] - by Guest - 12-28-2005, 08:42 PM
[No subject] - by Ron Ramirez - 12-28-2005, 10:27 PM
[No subject] - by Guest - 12-30-2005, 01:44 PM
