1939 Stromberg Carlson 430-H Restore on YouTube
Buzz;
  I think that someone replaced the speaker in your 430-H, the original one would have had a rectangular rear bracket holding the pole piece, field coil, and hum bucking coil, yours has one with a round bracket kind of like a Rolla or Lansing, and looks like it's painted gold so it may have come out of a Zenith or something else. The reason I think so is that the speaker cable looks like it was cut, spliced, and wrapped with friction tape. A guy on You Tube called farmall1938 has a restoration series for a 420-H which is a similar but cheaper model then your 430-H but more importantly his still has the plastic dial escutcheon that is missing from yours and the original Stromberg made speaker.
RE: 1939 Stromberg Carlson 430-H Restore on YouTube - by Arran - 06-29-2015, 04:03 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
