I need a good flocking..
    I have 3 record platters from 1950's Philcos that I need to reflock.  They were flocked originally by applying an electro static charge to the record platter - which produces a nice even and fluffy surface.  I can't find anyone who does this anymore online.   There is a company that makes an electrostatic flocking applicator device - costs about $120.00.  I wonder if any of you have tried this?  Company claims the high voltage charge follows the flocking fibers onto the surface you are flocking - wondering if this works well and will reproduce the nice even, soft surface found on these record platters from the 1950's.
https://www.craftflocking.com/shopping/p...d=258&=SID
[attachment=7621]
I need a good flocking.. - by ODPILOT - 06-29-2015, 01:37 PM
RE: I need a good flocking.. - by Jim Koehler - 07-06-2015, 10:40 AM
RE: I need a good flocking.. - by ODPILOT - 07-09-2015, 05:59 PM
There are currently 5934 online users. [Complete List]
» 2 Member(s) | 5932 Guest(s)
