Philco 37-62 head scratcher
You bet exray, but kinda weird listening to ESPN on a depression era radio! but its very cool..take care.
Philco 37-62 head scratcher - by Guest - 02-13-2009, 09:59 PM
Re: Philco 37-62 head scratcher - by exray - 02-13-2009, 10:56 PM
Re: Philco 37-62 head scratcher - by Guest - 02-13-2009, 11:16 PM
Re: Philco 37-62 head scratcher - by exray - 02-13-2009, 11:47 PM
Re: Philco 37-62 head scratcher - by Guest - 02-14-2009, 12:19 AM
Re: Philco 37-62 head scratcher - by Texasrocker - 02-14-2009, 03:06 AM
Re: Philco 37-62 head scratcher - by exray - 02-14-2009, 09:21 AM
Re: Philco 37-62 head scratcher - by Guest - 02-15-2009, 07:50 PM
Re: Philco 37-62 head scratcher - by exray - 02-15-2009, 07:58 PM
Re: Philco 37-62 head scratcher - by Guest - 02-15-2009, 10:48 PM
