Philco 39-55
The Mystery Control only turns OFF the set, as volume is decreased past minimum. You have to get up and turn it ON manually. Icon_smile
See my site for operational details.
Philco 39-55 - by Guest - 12-28-2005, 06:42 PM
[No subject] - by Chuck Schwark - 12-28-2005, 07:19 PM
[No subject] - by Guest - 12-28-2005, 07:27 PM
[No subject] - by Chuck Schwark - 12-28-2005, 07:43 PM
[No subject] - by Guest - 12-28-2005, 08:42 PM
[No subject] - by Ron Ramirez - 12-28-2005, 10:27 PM
[No subject] - by Guest - 12-30-2005, 01:44 PM
