Issue with rebuilt 38-690 audio transformer
Sorry Morzh, you will have to bear with me. I assumed there would be voltages going to the tweeter. A lot of this troubleshooting is somewhat new to me; the complexity of this set is ...
What I need to figure out is why there's no voltage going to the driver tube (6F6), and what other problems there may be in the power supply.
RE: Issue with rebuilt 38-690 audio transformer - by Diverted - 06-30-2015, 10:09 PM
There are currently 3862 online users. [Complete List]
» 1 Member(s) | 3861 Guest(s)
