Issue with rebuilt 38-690 audio transformer
Oh, sorry Morzh. I must have missed that one.
I don't see Choke 172. On my schematic, part 172 is the tweeter field coil.
The two chokes I see in the power supply chassis are 167 and 175. Both check out and have the right ballpark resistance. Am I missing something?
RE: Issue with rebuilt 38-690 audio transformer - by Diverted - 06-30-2015, 11:10 PM
