Issue with rebuilt 38-690 audio transformer
Well, let it be the field coil, it is still a choke. Check it. Voltages before and after will do for now.
RE: Issue with rebuilt 38-690 audio transformer - by morzh - 06-30-2015, 11:17 PM
There are currently 5900 online users. [Complete List]
» 2 Member(s) | 5898 Guest(s)
