Issue with rebuilt 38-690 audio transformer
Sorry, let me rephrase. Trying to write this clearly, and not succeeding.
Choke 175 has continuity, and voltage at same level as 6L6 plates.
You'd asked me to check voltage and continuity across Part 172, the tweeter choke. I attempted to, measuring from the black primary lead to the junction of 143 and the choke 175. I tried and got no continuity. While I got voltage on the side containing the 2K resistor (part 143) I got no voltage on the other side (I measured from the black primary lead of the interstage.
Sorry if that was confusing.
RE: Issue with rebuilt 38-690 audio transformer - by Diverted - 06-30-2015, 11:47 PM
There are currently 6033 online users. [Complete List]
» 1 Member(s) | 6032 Guest(s)
