Model 41-220 Parts list
HI Blaine
Try this schematic. http://www.nostalgiaair.org/PagesByModel...013395.pdf It has all the values and some parts location. Looks like this chassis was used for more than one radio.
Hope tis is what you need Icon_biggrin
Model 41-220 Parts list - by Blaine - 02-15-2009, 06:28 PM
Re: Model 41-220 Parts list - by Terry Burns - 02-16-2009, 09:30 AM
There are currently 11419 online users. [Complete List]
» 2 Member(s) | 11417 Guest(s)
