Model 96 Field coil.....
Hi Guys...
Ron's number seems to prove out that the FC is shorted. I'm reading 2,200 ohms DC. Together with the open primary on the OPT, the main problem is right here. The FC can be taken out of the speaker fairly easily so I think I'll rewind it.
Anyone know of a rewinding shop on the East Coast?....or have another Model 96 speaker they can spare?
Again Tnx....
...Jim
Model 96 Field coil..... - by Jim Koehler - 07-01-2015, 02:54 PM
RE: Model 96 Field coil..... - by morzh - 07-01-2015, 03:01 PM
RE: Model 96 Field coil..... - by Jim Koehler - 07-01-2015, 04:02 PM
RE: Model 96 Field coil..... - by morzh - 07-01-2015, 04:14 PM
RE: Model 96 Field coil..... - by Radioroslyn - 07-01-2015, 04:40 PM
RE: Model 96 Field coil..... - by morzh - 07-01-2015, 04:46 PM
RE: Model 96 Field coil..... - by codefox1 - 07-01-2015, 05:28 PM
RE: Model 96 Field coil..... - by Ron Ramirez - 07-01-2015, 07:54 PM
RE: Model 96 Field coil..... - by Radioroslyn - 07-01-2015, 08:36 PM
RE: Model 96 Field coil..... - by Jim Koehler - 07-01-2015, 08:47 PM
There are currently 4491 online users. [Complete List]
» 2 Member(s) | 4489 Guest(s)
