16b and model 20 pwr trans
dang! i couldn't find specs but i knew some one here would know.
i just got a 16b but it has the horizonal power trans[from a 4 bander maybe?] in it instead of the vertical. it works but i was trying to get it looking more original looking and i just bought a 20 tranny for $10 as a spare.
oh well,someday i'll get a deal on an original,thanks guys!
phil
edit; anyone know distinct code differences? no label so i'm trying to figure what the chassis code is. it's using the 5z3 for the rectifier,not an 80.
thanks,phil
16b and model 20 pwr trans - by philco phan - 02-16-2009, 05:50 PM
Re: 16b and model 20 pwr trans - by Steve Davis - 02-16-2009, 06:52 PM
Re: 16b and model 20 pwr trans - by Ron Ramirez - 02-16-2009, 06:53 PM
Re: 16b and model 20 pwr trans - by philco phan - 02-16-2009, 07:25 PM
Re: 16b and model 20 pwr trans - by philco phan - 02-16-2009, 10:34 PM
Re: 16b and model 20 pwr trans - by Steve Davis - 02-16-2009, 10:58 PM
Re: 16b and model 20 pwr trans - by Ron Ramirez - 02-16-2009, 11:56 PM
Re: 16b and model 20 pwr trans - by philco phan - 02-17-2009, 12:08 AM
Re: 16b and model 20 pwr trans - by philco phan - 02-17-2009, 01:28 AM
Re: 16b and model 20 pwr trans - by philco phan - 02-17-2009, 11:05 PM
Re: 16b and model 20 pwr trans - by Ron Ramirez - 02-18-2009, 12:06 AM
Re: 16b and model 20 pwr trans - by philco phan - 02-18-2009, 01:24 AM
Re: 16b and model 20 pwr trans - by Ron Ramirez - 02-18-2009, 07:11 AM
Re: 16b and model 20 pwr trans - by philco phan - 02-18-2009, 07:00 PM
Re: 16b and model 20 pwr trans - by philco phan - 02-18-2009, 08:46 PM
Re: 16b and model 20 pwr trans - by radiomikee - 02-27-2009, 01:13 PM
Re: 16b and model 20 pwr trans - by philco phan - 02-28-2009, 01:03 PM
There are currently 4460 online users. [Complete List]
» 1 Member(s) | 4459 Guest(s)
