41-295 questions
Thanks Skip and Terry. For the sake of not wanting to get buried in a particular set, I think I'll "try" and confine my searching to the earlier than '38 sets. The chassis resto on my 39-17 was a bit expensive recently, due to all that rubber wiring. Luckily I got the radio very reasonably. Still, I'm into it more than it's worth. Good thing I'm in the hobby to enjoy it and not make money!!
I like the style of 37-116 consoles. Are they cloth braided wiring, not rubber?
41-295 questions - by SteveG - 07-04-2015, 01:30 AM
RE: 41-295 questions - by Ron Ramirez - 07-04-2015, 08:09 AM
RE: 41-295 questions - by SteveG - 07-04-2015, 01:58 PM
RE: 41-295 questions - by vecher - 07-04-2015, 05:00 PM
RE: 41-295 questions - by Radioroslyn - 07-04-2015, 06:19 PM
RE: 41-295 questions - by SteveG - 07-04-2015, 06:36 PM
RE: 41-295 questions - by Ron Ramirez - 07-04-2015, 07:20 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
