41-280 pushbutton station selection fine, no oscillator output on manual tuning bands
The schematic links are meant to help those who are trying to answer your questions as well as for you if you did not have them.
There are currently 4392 online users. [Complete List]
» 1 Member(s) | 4391 Guest(s)
