Philco 37-61 tuning rod assembly
Hello Phorum,
I'm looking for help finding for the size o-ring that is used on the 37-61 variable capacitor tuning rod assembly.
Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 10:05 AM
RE: Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 01:56 PM
RE: Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 05:00 PM
There are currently 3390 online users. [Complete List]
» 1 Member(s) | 3389 Guest(s)
