Philco 37-61 tuning rod assembly
I've never heard of - nor seen - any O-rings on any of the Philco ball bearing shaft assemblies that I've worked with.
Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 10:05 AM
RE: Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 01:56 PM
RE: Philco 37-61 tuning rod assembly - by Ron Ramirez - 07-06-2015, 03:04 PM
RE: Philco 37-61 tuning rod assembly - by Stonne - 07-06-2015, 05:00 PM
There are currently 6605 online users. [Complete List]
» 2 Member(s) | 6603 Guest(s)
