Lee's 37-630 chassis saga
Lee,
If you are referring to that big tubular thing with the black woven cloth around it that connects between one of the e-caps at the left and the bakelite block over toward right-center, I'm pretty sure that that was a resistor.  You have to remember that some of the schematics and chassis drawings from this era contained mistakes.
So as I said, I believe it is just a 2 W dogbone resistor.  Can you post a picture of that item after the cloth was removed?
Lee's 37-630 chassis saga - by NN7X - 07-04-2015, 12:12 AM
RE: Lee's 37-630 chassis saga - by Radioroslyn - 07-04-2015, 06:20 AM
RE: Lee's 37-630 chassis saga - by mikethedruid - 07-04-2015, 10:45 AM
RE: Lee's 37-630 chassis saga - by PAradiogeek - 07-04-2015, 05:26 PM
RE: Lee's 37-630 chassis saga - by NN7X - 07-04-2015, 11:18 PM
RE: Lee's 37-630 chassis saga - by PAradiogeek - 07-06-2015, 04:43 PM
RE: Lee's 37-630 chassis saga - by Crist Rigotti - 07-06-2015, 04:45 PM
RE: Lee's 37-630 chassis saga - by Radioroslyn - 07-06-2015, 05:55 PM
RE: Lee's 37-630 chassis saga - by NN7X - 07-06-2015, 09:55 PM
RE: Lee's 37-630 chassis saga - by Crist Rigotti - 07-06-2015, 11:17 PM
RE: Lee's 37-630 chassis saga - by NN7X - 07-07-2015, 08:11 AM
RE: Lee's 37-630 chassis saga - by Crist Rigotti - 07-07-2015, 10:56 PM
RE: Lee's 37-630 chassis saga - by NN7X - 07-13-2015, 11:43 PM
RE: Lee's 37-630 chassis saga - by Warren - 07-14-2015, 12:07 AM
RE: Lee's 37-630 chassis saga - by KCMike - 07-14-2015, 10:05 AM
There are currently 5739 online users. [Complete List]
» 3 Member(s) | 5736 Guest(s)
