Model 65 Hiboy
Hi All
I am new to the group. I acquired a mod 65 highboy that I am trying to restore but it has some items in the chassis that do not match the Ryder schematic I have. I found a bad ant primary coil that I will rewind but this coil looks to have a center tap and a switch. The schematic shows a 5K resistor to gnd.
I was wondering if any of you experts would enlighten me if someone had run across this before
any help would be greatly appreciated.
Bob L.
Model 65 Hiboy - by Bob L. - 07-06-2015, 08:25 PM
RE: Model 65 Hiboy - by Radioroslyn - 07-06-2015, 09:59 PM
RE: Model 65 Hiboy - by Ron Ramirez - 07-07-2015, 06:13 AM
RE: Model 65 Hiboy - by Bob L. - 07-08-2015, 06:13 PM
RE: Model 65 Hiboy - by klondike98 - 07-08-2015, 06:38 PM
RE: Model 65 Hiboy - by Radioroslyn - 07-09-2015, 05:36 PM
Model 65 Hiboy - by klondike98 - 07-06-2015, 09:11 PM
There are currently 4223 online users. [Complete List]
» 1 Member(s) | 4222 Guest(s)
