41-280 pushbutton station selection fine, no oscillator output on manual tuning bands
Well...on the bright side, Philco made a bazillion of those 41-280 sets, so you shouldn't have any problem finding a replacement coil. Other similar Philcos include the 41-250, 41-255, 41-285, 41-287, 41-290, 41-296.
