Philco 20 delux
Hello Gary,
thanks for the info far as electricaly restoring this set I don't think I'll have any problems with the advice you have given me I
think it will be a straight forward job Since I know the set works thats a big plus in my book.
Sincerely Rich
P.S. there is a slight minor crack on one of the sides closer to the top curve I take a photo of it and email to you Gary.
Philco 20 delux - by radiorich - 02-05-2009, 05:25 PM
Re: Philco 20 delux - by Arran - 02-05-2009, 07:20 PM
Re: Philco 20 deluxe - by radiorich - 02-05-2009, 08:27 PM
Re: Philco 20 delux - by Arran - 02-05-2009, 10:36 PM
Re: Philco 20 delux - by radiorich - 02-08-2009, 09:31 PM
Re: Philco 20 delux - by gary rabbitt - 02-17-2009, 09:40 PM
Re: Philco 20 delux - by radiorich - 02-18-2009, 03:14 AM
Re: Philco 20 delux - by gary rabbitt - 02-18-2009, 03:17 PM
Re: Philco 20 delux - by radiorich - 02-18-2009, 04:11 PM
There are currently 9975 online users. [Complete List]
» 1 Member(s) | 9974 Guest(s)
