Philco 90 original finish preservation
I have sometimes used a penetrating oil finish on aged lacquer: thinned varnish, boiled linseed oil, tung oil, Minwax "Antique Oil," there are many. Occasionally I've heated the surface with an infrared lamp to aid penetration. Any oil remaining on the surface is wiped off before it sets.
RE: Philco 90 original finish preservation - by Alan Douglas - 07-09-2015, 08:03 PM
There are currently 9008 online users. [Complete List]
» 3 Member(s) | 9005 Guest(s)
