Philco 53 960 Tropic
I do not believe it has a fuse. Edit: I looked at the schematic...nope, no fuse.
If it comes down to a power transformer, I have a 53-960 parts chassis. I need the front end components for my 42-761EZ, but let me know if you need the power transformer - I believe it is OK...
Philco 53 960 Tropic - by SteveJB - 07-09-2015, 09:07 AM
RE: Philco 53 960 Tropic - by JimZ - 07-09-2015, 09:43 AM
RE: Philco 53 960 Tropic - by Steve Davis - 07-09-2015, 09:44 AM
RE: Philco 53 960 Tropic - by JimZ - 07-09-2015, 09:46 AM
RE: Philco 53 960 Tropic - by morzh - 07-09-2015, 11:15 AM
RE: Philco 53 960 Tropic - by SteveJB - 07-09-2015, 12:28 PM
RE: Philco 53 960 Tropic - by Ron Ramirez - 07-09-2015, 12:30 PM
RE: Philco 53 960 Tropic - by SteveJB - 07-09-2015, 04:11 PM
RE: Philco 53 960 Tropic - by Ron Ramirez - 07-09-2015, 06:29 PM
RE: Philco 53 960 Tropic - by SteveJB - 07-09-2015, 06:51 PM
RE: Philco 53 960 Tropic - by Ron Ramirez - 07-09-2015, 09:57 PM
RE: Philco 53 960 Tropic - by SteveJB - 07-10-2015, 07:05 AM
RE: Philco 53 960 Tropic - by SteveJB - 07-11-2015, 07:48 AM
RE: Philco 53 960 Tropic - by Ron Ramirez - 07-11-2015, 07:55 AM
RE: Philco 53 960 Tropic - by SteveJB - 07-11-2015, 10:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7086 online users. [Complete List]
» 1 Member(s) | 7085 Guest(s)
