Philco 19-126 tone control
Hi Folks.  I got my 19 electronically restored but I have one little hiccup.  The tone control is a 4 position switch that is coupled between the output tube and the volume control tap.  Now position 1,2 and 4 are fine but in position 3 I get a nasty squeal when the volume is up past about one third. Has anyone else experienced this?
Happiness is a warm glowing radio!
Philco 19-126 tone control - by earlyradios - 07-12-2015, 11:34 AM
RE: Philco 19-126 tone control - by Radioroslyn - 07-12-2015, 11:56 AM
RE: Philco 19-126 tone control - by earlyradios - 07-12-2015, 03:05 PM
RE: Philco 19-126 tone control - by Radioroslyn - 07-12-2015, 06:34 PM
RE: Philco 19-126 tone control - by earlyradios - 07-12-2015, 08:47 PM
There are currently 5953 online users. [Complete List]
» 2 Member(s) | 5951 Guest(s)
